Volvo
Volvo v90 tagaurduskaamera
intsuzu
17:53 18.02.2022
Tere. Sooviks teada kas kellegil ka selline jama tekkinud. Tagurpidi käigu sisse lülitusel korraks pilt ees ja siis selline edasi nagu pildil. Viga tekkis äkitselt, poodi minnes töötas ja tulles oli pilt selline. Kas tegu tarkvara probleemiga või juhtme viga. Auto
aastast 2016. D5.
daas
19:06 18.02.2022
. Put the car in reverse - no backup image in camera.
. Manually turn the camera on by pressing CAM (camera) button on center console.
. Press MENU on the rotary TUNE dial located on the center console.
. Up pops up the camera menu, of which the first option on the list is to automatically turn on the camera when the car is put in reverse.
. Place a check in the option to automatically turn on the camera.
. Press EXIT on the rotary TUNE dial to save your change.
intsuzu
20:07 18.02.2022
Ma ei tea kas pean ingliskeeles kirjutama aga pole sellist menüüd v90 minul vähemalt. Dont have that kind of menu on the center console. Added a picture of my console. In the menu like manual says i also dont have a place where i can turn it off or on, its like its always on. I tried holding buttons while doing as you said but raidio muted only.
intsuzu
10:19 19.02.2022
