Volkswagen Tiguan 2019
feux
19:49 03.10.2024
Kuidas kustutada auto armatuurist Tehnilise ülevaatus tekst?
Panakas
20:53 03.10.2024
Njah b
22:14 03.10.2024
1. Using the Infotainment System:
Turn on the ignition: Make sure the engine is off.
Access the service menu: Use the infotainment system's buttons to navigate to the service menu. This is typically found under "Settings," "Vehicle," or a similar option.
Select "Reset Inspection": Look for an option that says "Reset Inspection" or something similar.
Confirm the reset: Follow the prompts on the screen to confirm the reset.
2. Using the Steering Wheel Controls:
Locate the reset button: Some models have a dedicated reset button on the steering wheel. It might be labeled "OK," "Menu," or something similar.
Press and hold the button: Press and hold the reset button for a few seconds.
Select "Reset Inspection": A menu should appear on the instrument cluster. Use the steering wheel controls to navigate to "Reset Inspection" and select it.
